メインコンテンツにスキップ
  1. Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off. Use the tweezers to lift the faceplate  from the rest of the device. The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. Using a #00 Phillips head screwdriver, remove the following screws: One 4.6 mm screw
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  4. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  5. Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection. Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard. During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
まとめ
Thomas Sullivan
メンバー登録日: 2017年02月20日
537 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S2G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 40
