メインコンテンツにスキップ
GoPro Hero4 Black Lens Replacement
必要な工具と部品
  1. GoPro Hero4 Black Lens Replacement, Midframe Housing: 手順 1、 3の画像 1 GoPro Hero4 Black Lens Replacement, Midframe Housing: 手順 1、 3の画像 2 GoPro Hero4 Black Lens Replacement, Midframe Housing: 手順 1、 3の画像 3
    この手順で使用する道具:
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Lens Replacement: 手順 2、 2の画像 1 GoPro Hero4 Black Lens Replacement: 手順 2、 2の画像 2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Lens Replacement: 手順 3、 2の画像 1 GoPro Hero4 Black Lens Replacement: 手順 3、 2の画像 2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Lens Replacement: 手順 4、 3の画像 1 GoPro Hero4 Black Lens Replacement: 手順 4、 3の画像 2 GoPro Hero4 Black Lens Replacement: 手順 4、 3の画像 3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black Lens Replacement, Camera Sensor: 手順 5、 3の画像 1 GoPro Hero4 Black Lens Replacement, Camera Sensor: 手順 5、 3の画像 2 GoPro Hero4 Black Lens Replacement, Camera Sensor: 手順 5、 3の画像 3
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. GoPro Hero4 Black Lens Replacement: 手順 6、 3の画像 1 GoPro Hero4 Black Lens Replacement: 手順 6、 3の画像 2 GoPro Hero4 Black Lens Replacement: 手順 6、 3の画像 3
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
  7. GoPro Hero4 Black Lens Replacement, Lens: 手順 7、 2の画像 1 GoPro Hero4 Black Lens Replacement, Lens: 手順 7、 2の画像 2
    • Three 2 mm screw
  8. GoPro Hero4 Black Lens Replacement: 手順 8、 1の画像 1
    • Lift the lens from the front housing.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Thomas Sullivan
メンバー登録日: 02/20/17
595 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S2G1
4 メンバー
12のガイドは作成済み
1件のガイドコメント
Between step 6 and step 7, you skipped a really important step…
Matthew Mulholland - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 38
今までの合計 4,696
