この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show how to replace the camera sensor. The camera sensor collects light to create the image. If your pictures are blurry or low on brightness, the camera sensor may need a replacement.
必要な工具と部品
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
7 の人々がこのガイドを完成させました。
2 件のコメント
not easy to return the ribbon back to its place! it’s easier to throw your gopro after doing this.
popoypoi22 - 返信
Hi, is the sensor for black and silver same? Thank you
