この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Can your GoPro no longer capture anything? You try to record your awesomeness and nothing? You may need to replace your image sensor, and this guide will have you filming your latest skydiving adventure in no time!
必要な工具と部品
Pull the tab on the back of the device to release the back cover. It should come right off.
Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
6 の人々がこのガイドを完成させました。
