メインコンテンツにスキップ
GoPro Hero3+ Black Edition Image Sensor Replacement
必要な工具と部品
  1. GoPro Hero3+ Black Edition Image Sensor Replacement, Battery: 手順 1、 1の画像 1
    • Pull the tab on the back of the device to release the back cover. It should come right off.
    • The device pictured does not include the back cover.
  2. GoPro Hero3+ Black Edition Image Sensor Replacement: 手順 2、 1の画像 1
    • Use the battery tab to pull the battery out of the device.
    • Remove the battery from the slot.
  3. GoPro Hero3+ Black Edition Image Sensor Replacement, Front Face Plate: 手順 4、 2の画像 1 GoPro Hero3+ Black Edition Image Sensor Replacement, Front Face Plate: 手順 4、 2の画像 2
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
  4. GoPro Hero3+ Black Edition Image Sensor Replacement, Image Sensor: 手順 5、 3の画像 1 GoPro Hero3+ Black Edition Image Sensor Replacement, Image Sensor: 手順 5、 3の画像 2 GoPro Hero3+ Black Edition Image Sensor Replacement, Image Sensor: 手順 5、 3の画像 3
    • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
    • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
    • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
  5. GoPro Hero3+ Black Edition Image Sensor Replacement: 手順 6、 2の画像 1 GoPro Hero3+ Black Edition Image Sensor Replacement: 手順 6、 2の画像 2
    • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
  6. GoPro Hero3+ Black Edition Image Sensor Replacement: 手順 7、 1の画像 1
    • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
    • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
  7. GoPro Hero3+ Black Edition Image Sensor Replacement: 手順 8、 1の画像 1
    • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
    • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
  8. GoPro Hero3+ Black Edition Image Sensor Replacement: 手順 9、 2の画像 1 GoPro Hero3+ Black Edition Image Sensor Replacement: 手順 9、 2の画像 2
    • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
    • Remove the image sensor from the motherboard assembly.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kyle Rooney
メンバー登録日: 04/14/15
502 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 6-15, Maness Spring 2015 Cal Poly, Team 6-15, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S6G15
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,226
