メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GoPro Hero 4 Black USB Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. GoPro Hero 4 Black USB Replacement, Replacing USB Port: 手順 1、 1の画像 1
    • First, you will have to remove the faceplate by carefully using the spudger around the edge to loosen the clips.
    • After loosening the clips on the edge, pull the faceplate off.
    • Be aware that there is double-sided tape on the backside of the faceplate (indicated by the red arrow).
  2. GoPro Hero 4 Black USB Replacement: 手順 2、 1の画像 1
    • Now, you will need to take a PH000 Philips head screwdriver and remove the 4 corner screws.
    • Note: The screws circled in red are longer than the screw circled in orange.
  3. GoPro Hero 4 Black USB Replacement: 手順 3、 1の画像 1
    • Now, you will need to remove the camera and boards from the black plastic housing. You may use any tool that will do the job. My group found out, if you use the plastic tool to remove the boards and camera, that it would assist you with the removal.
  4. GoPro Hero 4 Black USB Replacement: 手順 4、 1の画像 1
    • Remove the ribbon strip by carefully pulling on it. It should slide out of its connection.
    • When you push down on the three wires that are connected to the clip. The clip will disconnect from the motherboard.
  5. GoPro Hero 4 Black USB Replacement: 手順 5、 1の画像 1
    • Take yourPH000 Philips head screwdriver to remove the four screws outlined in red.
    • Once the screws are removed. Gently remove the board and as you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
  6. GoPro Hero 4 Black USB Replacement: 手順 6、 1の画像 1
    • Take your PH000 Philips head screwdriver and remove the three screws that are outlined in red.
    • Just like before, gently pull up on the ribbon strip to remove the connector from the motherboard.
  7. GoPro Hero 4 Black USB Replacement: 手順 7、 1の画像 1
    • Remove the two screws to remove the riser that is being held in place by the screws.
  8. GoPro Hero 4 Black USB Replacement: 手順 8、 1の画像 1
    • Remove a single screw located near the barcode.
    • Note: Once the screw is removed, only the ribbon strip on the bottom of the motherboard is holding it.
  9. GoPro Hero 4 Black USB Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    • At the top of the ribbon strip, there is a black clip that will need to be popped up.
    • Note: You can use your finger to pop the clip, but a pair of tweezers might be of help.
  10. GoPro Hero 4 Black USB Replacement: 手順 10、 1の画像 1
    • Gently, grab the ribbon with a pair of tweezers to disconnect the ribbon from the connecter.
    • Now, the motherboard can be removed. Due to the USB connector being soldered to the motherboard, the entire board will need to be replaced.
終わりに
8 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jonathan Campbell
メンバー登録日: 09/29/15
830 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-2, Hagerty Fall 2015 IUPUI, Team 1-2, Hagerty Fall 2015人のメンバー
IUPUI-HAGERTY-F15S1G2
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 22
今までの合計 3,813
