メインコンテンツにスキップ
GoPro Hero 3 Silver Image Sensor Replacement
必要な工具と部品
  1. GoPro Hero 3 Silver Image Sensor Replacement, Battery: 手順 1、 2の画像 1 GoPro Hero 3 Silver Image Sensor Replacement, Battery: 手順 1、 2の画像 2
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Image Sensor Replacement: 手順 2、 1の画像 1
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: 手順 3、 2の画像 1 GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: 手順 3、 2の画像 2
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Image Sensor Replacement: 手順 4、 2の画像 1 GoPro Hero 3 Silver Image Sensor Replacement: 手順 4、 2の画像 2
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Image Sensor Replacement: 手順 5、 2の画像 1 GoPro Hero 3 Silver Image Sensor Replacement: 手順 5、 2の画像 2
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Image Sensor Replacement: 手順 6、 2の画像 1 GoPro Hero 3 Silver Image Sensor Replacement: 手順 6、 2の画像 2
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Image Sensor Replacement: 手順 7、 2の画像 1 GoPro Hero 3 Silver Image Sensor Replacement: 手順 7、 2の画像 2
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  8. GoPro Hero 3 Silver Image Sensor Replacement: 手順 8、 2の画像 1 GoPro Hero 3 Silver Image Sensor Replacement: 手順 8、 2の画像 2
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • You should now be able to remove the image sensor by simply pulling it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jose Villa
メンバー登録日: 04/01/15
297 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G7
3 メンバー
21のガイドは作成済み
2 件のコメント
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - 返信
Your pictures are really dark.
Nick Ruiz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,854
