メインコンテンツにスキップ
  1. Pull back on the tab on the back of GoPro to open the battery cover. Pull back on the tab on the back of GoPro to open the battery cover.
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. Pull the battery out using the tab.
    • Pull the battery out using the tab.
  3. Use the plastic opening tool to remove the faceplate. There is some adhesive and clips so be careful and the faceplate should pop right off.
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. Now that the faceplate is off, it is time to remove the 4 screws on each corner. Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier. Using the plastic opening tool, slowly pry open the motherboard assembly.
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. Use the spudger to gently pry off the connector of the housing to the motherboard. You should now have the motherboard assembly and the housing separated.
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard. Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  8. Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off. You should now be able to remove the image sensor by simply pulling it.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • You should now be able to remove the image sensor by simply pulling it.
終わりに
2 の人々がこのガイドを完成させました。
Jose Villa
メンバー登録日: 2015年04月01日
291 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G7
3 メンバー
21のガイドは作成済み
2 件のコメント
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - 返信
Your pictures are really dark.
Nick Ruiz - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 1,562
