メインコンテンツにスキップ
はじめに
Are the circuits of your GoPro's motherboard fried from water damage? This guide provides steps on how to replace a GoPro Hero 3+ Silver Motherboard and get your camera back in working condition.
  1. Push the tab on the back of the device left to remove the plate covering the battery. Push the tab on the back of the device left to remove the plate covering the battery.
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. Use the strip of tape on the battery to remove the battery from the housing.
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. Insert a plastic opening tool in between the front face plate and the black housing.
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  6. Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver. Gently remove the motherboard by using a plastic opening tool to pry it out of the housing. Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    Is this the power cable?
    David - 返信
  7. Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out. Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  8. Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  9. Pry off the last ribbon cable with a plastic opening tool. Remove the image sensor from the motherboard.
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  10. Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  11. Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard. Gently remove the motherboard from the midframe using tweezers. Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
まとめ
3 の人々がこのガイドを完成させました。
Blake Ehlers
メンバー登録日: 2015年10月01日
641 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S5G8
4 メンバー
6のガイドは作成済み
コメント1件
hi, where i can find the matherboard for de hero 3+ silver?
Mauricio - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 2,316
