はじめに
Dude 1: Dude! Check out this sweet video I just made of me mountain biking through an alligator-filled swamp! Here, take my SD card.
Dude 2: Dude, there's nothing here. It's just an empty 32 GB SD card. I should've known that you weren't hardcore.
Dude 1: No dude, I swear it happened! My SD card reader must be dead.
Don't be like Dude 1. Make sure your precious memories are recorded to your SD card and replace a faulty SD board in your GoPro.
必要な工具と部品
Place your thumb on the indentation in the back case on the side of the GoPro.
Gently press down with your thumb and lift the back cover away from the case to remove it.
Slide a plastic opening tool between the battery and the rear case.
Gently pry the battery up and out of the rear case.
Remove the four Phillips #00 screws securing the rear case to the rest of the device:
Two 5.5 mm coarse thread screws.
Two 4.4 mm fine thread screws.
Remove the two 5.8 mm Phillips #00 screws securing the SD board cover to the rear case.
Use a plastic opening tool or your fingernail to flip up the locking tab on the SD board ribbon cable ZIF connector.
Remove the SD board ribbon cable.
3 の人々がこのガイドを完成させました。
