メインコンテンツにスキップ
Glass Door Latch Replacement
必要な工具と部品
  1. Glass Door Latch Replacement, Outer Removal: 手順 1、 3の画像 1 Glass Door Latch Replacement, Outer Removal: 手順 1、 3の画像 2 Glass Door Latch Replacement, Outer Removal: 手順 1、 3の画像 3
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: 手順 2、 3の画像 1 Glass Door Latch Replacement, Preparation: 手順 2、 3の画像 2 Glass Door Latch Replacement, Preparation: 手順 2、 3の画像 3
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: 手順 3、 2の画像 1 Glass Door Latch Replacement: 手順 3、 2の画像 2
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: 手順 4、 2の画像 1 Glass Door Latch Replacement, Mechanism Removal: 手順 4、 2の画像 2
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: 手順 5、 2の画像 1 Glass Door Latch Replacement, Replacement Prep: 手順 5、 2の画像 2
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: 手順 6、 3の画像 1 Glass Door Latch Replacement, Installation: 手順 6、 3の画像 2 Glass Door Latch Replacement, Installation: 手順 6、 3の画像 3
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: 手順 7、 3の画像 1 Glass Door Latch Replacement, Installation Cont.: 手順 7、 3の画像 2 Glass Door Latch Replacement, Installation Cont.: 手順 7、 3の画像 3
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: 手順 8、 2の画像 1 Glass Door Latch Replacement, Latch Correction: 手順 8、 2の画像 2
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: 手順 9、 3の画像 1 Glass Door Latch Replacement, Handle Placement: 手順 9、 3の画像 2 Glass Door Latch Replacement, Handle Placement: 手順 9、 3の画像 3
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
終わりに
作成者
3人の作成者と共同で作成されました。
CJ Cummings
メンバー登録日: 05/04/20
169 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G32, Cardinal Spring 2020 UW Tacoma, Team S1-G32, Cardinal Spring 2020人のメンバー
UWT-CARDINAL-S20S1G32
1 メンバー
1のガイドは作成済み
コメント 1 件
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 41
過去 30 日: 161
今までの合計 6,561
