はじめに
Glade Automatic Spray Holder SJC-180 could have some loose wires or a burnt circuit on the circuit board. The guide will show you the wire connection areas and circuit boards with problems and how to fix it.
必要な工具と部品
Press the button labelled glade to open the housing.
Locate the timer switch and slide it to off.
Use small needle nose pliers to gently remove each terminal. Check if any wires are disconnected or loose.
The terminals with negative connections (black wires) could have breaks or might have detached from the terminal base. Check for additional issues.
The bottom terminal is one piece instead of two pieces like the top ones.
Remove the four screws using Phillips screwdriver. Gently pull the screws straight out to avoid disrupting the components you are exposing.
Once the cover is removed, take a picture to reference when you're reassembling the device. The larger electrical board is on the top. The plastic gears are easily moved out of their positions when removing cover and board.
The first circuit board to inspect has the timer switch on it. This circuit board is the larger of the two that are part of the device.
The circuit board is held in place by 3 pegs. The pegs are plastic. This means you do not need special tools to remove the circuit board. It will pop off using your fingers.
Flip the board over to look for loose wires or any burnt spots. This one is okay.
It is best to remove plastic gears before flipping the plastic plate holding everything together. The gears will fall out. Start with the fan shape gear. No tools are needed; each gear is held into place by pegs.
Next remove the largest gear. It is centrally located.
Lastly, remove the medium sized gear located towards the bottom left.
Solder the red wire back to the correct point on the circuit board. You'll be able to see the original factory solder point close to the edge of the board. It will be next to the black wire.
Once done with the solder, wait until it has cooled and pull gently to verify that it is securely attached to the circuit board.
Finished the circuit board and wire reattachment.
