はじめに
The hard drive stores some of the computer's files and has limited space. Replacement of the hard drive is necessary if it is broken or there is no space left.
It may be advantageous to upgrade the hard drive to a Solid State Drive (SSD) as their advantages over a traditional hard drive include: faster load times, longer lasting and more durable, use less power, and are quieter.
Upon opening the laptop casing disconnect the battery to reduce the risk of a power overload. This guide shows how:
Gigabyte P34G Battery Replacement
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds. Additional methods are discussed here:
必要な工具と部品
ある他の人がこのガイドを完成しました。
