Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
Push the axle screw to reveal the axle rod on the other side.
Using the Allen wrench, finish unscrewing the axle screw and pull it out.
Hold the wheel when pulling out the axle rod so that the bike does not fall.
Twist and pull off the cap covering the tire valve
Twist off the spacer that holds the valve in place.
Push valve in toward wheel to release air pressure.
Insert one tire lever between the tire and the rim.
Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
Insert a second tire lever next to the first.
Slowly slide one tire lever around the rim until the tire is released from the rim.
Using a tire lever, push the rim tape aside to reveal the spoke nipple.
Using your fingers, pull off the old spoke nipple.
Insert a new 250mm spoke into the hub.
Align the spoke with the spoke nipple in the rim.
Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
