Be sure the grill is turned off before beginning this guide.
Remove all of the control knobs.
The amount of knobs may vary depending on the grill.
Push up on the front panel, and pull it up above the grill.
Potential for device damage: The ignitor is connected to the front panel, so do not pull too hard.
Have the new ignitor on hand, and make sure that the clips on the side are in good condition.
Ensure that the pins at the end are straight and not bent.
Make sure any and all cables are separated from the fire box (the bottom of the grill).
Slot the panel back on the grill and then push downward.
The fire box is the part of the grill that gets really hot, and this can damage the cables.
Make sure the holes match and reinsert the screws from Step 2 using a Phillips #3 screwdriver.
If the holes do not match up, you may have to gently push or pull the front plastic panel.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
