メインコンテンツにスキップ
Genesis II CSS-315 Ignitor Replacement
必要な工具と部品
  1. Genesis II CSS-315 Ignitor Replacement, Ignitor: 手順 1、 2の画像 1 Genesis II CSS-315 Ignitor Replacement, Ignitor: 手順 1、 2の画像 2
    • Be sure the grill is turned off before beginning this guide.
    • Remove all of the control knobs.
    • The amount of knobs may vary depending on the grill.
  2. Genesis II CSS-315 Ignitor Replacement: 手順 2、 2の画像 1 Genesis II CSS-315 Ignitor Replacement: 手順 2、 2の画像 2
    • Remove the two 19 mm screws below the control knob panel using a Phillips #3 screwdriver.
  3. Genesis II CSS-315 Ignitor Replacement: 手順 3、 2の画像 1 Genesis II CSS-315 Ignitor Replacement: 手順 3、 2の画像 2
    • Push up on the front panel, and pull it up above the grill.
    • Potential for device damage: The ignitor is connected to the front panel, so do not pull too hard.
  4. Genesis II CSS-315 Ignitor Replacement: 手順 4、 2の画像 1 Genesis II CSS-315 Ignitor Replacement: 手順 4、 2の画像 2
    • Disconnect the cables from the ignitor.
  5. Genesis II CSS-315 Ignitor Replacement: 手順 5、 1の画像 1
    • Pinch the two ends of the ignitor and remove the ignitor from the front panel.
  6. Genesis II CSS-315 Ignitor Replacement: 手順 6、 1の画像 1
    • Have the new ignitor on hand, and make sure that the clips on the side are in good condition.
    • Ensure that the pins at the end are straight and not bent.
  7. Genesis II CSS-315 Ignitor Replacement: 手順 7、 3の画像 1 Genesis II CSS-315 Ignitor Replacement: 手順 7、 3の画像 2 Genesis II CSS-315 Ignitor Replacement: 手順 7、 3の画像 3
    • Put the new ignitor into the socket.
    • Press down evenly until it is secure.
  8. Genesis II CSS-315 Ignitor Replacement: 手順 8、 1の画像 1
    • Connect the white cables to the ignitor.
  9. Genesis II CSS-315 Ignitor Replacement: 手順 9、 2の画像 1 Genesis II CSS-315 Ignitor Replacement: 手順 9、 2の画像 2
    • Make sure any and all cables are separated from the fire box (the bottom of the grill).
    • Slot the panel back on the grill and then push downward.
    • The fire box is the part of the grill that gets really hot, and this can damage the cables.
  10. Genesis II CSS-315 Ignitor Replacement: 手順 10、 1の画像 1
    • Make sure the holes match and reinsert the screws from Step 2 using a Phillips #3 screwdriver.
    • If the holes do not match up, you may have to gently push or pull the front plastic panel.
  11. Genesis II CSS-315 Ignitor Replacement: 手順 11、 2の画像 1 Genesis II CSS-315 Ignitor Replacement: 手順 11、 2の画像 2
    • Add the control knobs, and slot them into place.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Carlos Castro Paguaga
メンバー登録日: 01/18/21
253 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G5, Woodhouse Spring 2021 York University, Team S1-G5, Woodhouse Spring 2021人のメンバー
YORK-WOODHOUSE-S21S1G5
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 29
今までの合計 570
