はじめに
Follow this guide to replace the rectifier diodes on a Genesis GHG1500A Dual Temperature Heat Gun.
If you find that the heat gun is not working and your multimeter indicates a shorted diode, then this guide should help.
I recommend replacing all 4 diodes so that all of the diodes have the same specs. This should reduce the likelihood of compatibilty issues in the future.
必要な工具と部品
Remove the seven 14mm screws from the side of the drill using a phillips screwdriver.
Remove the top casing to reveal inside of drill.
Using a phillips screwdriver remove the two 12.5 mm screws that are holding the fan housing to the bottom case.
Lift switch out of the bottom case.
Lift wires out of their retaining slots.
Seperate the fan unit from the plastic housing that is attached to the metal shield.
Position fan and metal shield so that you can comfortably work on the circuit board located on the top of the motor.
Add fresh solder to both ends of the diode and quickly move the soldering iron back and forth between both ends of the diode until the diode is released from the pads.
Method 2 (2 soldering irons) [Photo 2]
Heat up both soldering irons.
Add fresh solder to both ends of the diode. (Photo 1)
Hold soldering irons on both ends of the diode and lift the diode off of the circuit board once the solder melts. (Photo 2)
Repeat the above steps for the remaining diodes.
Remove excess solder from pads. (Link to desoldering video and the importance of flux)
Add flux to the pads
Apply flux to desoldering wick braid
Place desoldering wick braid on top of the pad
Press the iron on the braid until the solder on the board wicks into the braid.
Repeat above steps for the remaining pads.
Add flux to pad. (Photo 1)
Add small amount of solder to the tip of the iron. (Photo 2)
Use tweezers to hold the diode centered in between both pads. (Photo 3)
Touch the iron to the pad to tack the diode into position
Add flux to second pad. (Photo 1)
Hold iron onto the second end of the diode and feed solder onto the board right at the tip of the soldering iron. (Photo 2)
Revisit the first end of the diode and repeat the step above to ensure a sufficient amount of flux is on the pad. (Photo 3)
Use isopropyl alcohol on a q-tip to clean any excess flux left on the board.
