メインコンテンツにスキップ
General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement
必要な工具と部品
  1. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement, Reverse Switch: 手順 1、 1の画像 1
    • Before you begin, make sure the drain cleaner is disconnected from power.
    • Use a Phillips #2 driver to remove the two screws securing the control box cover.
  2. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 2、 1の画像 1
    • Remove the control box cover.
  3. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 3、 1の画像 1
    • Use a 9/16 inch deep socket and ratchet to remove the nut securing the reverse switch.
  4. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 4、 2の画像 1 General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 4、 2の画像 2
    • Remove the reverse switch guard.
  5. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 5、 2の画像 1 General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 5、 2の画像 2
    • Squeeze the tabs on either side of the reverse switch connector.
    • Pull the two halves of the connector apart to disconnect it.
    • Take note of where everything is connected in the control box before disconnecting anything else.
  6. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 6、 2の画像 1 General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 6、 2の画像 2
    • Pull the white cable straight off of its spade connector on the power switch diaphragm.
  7. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 7、 2の画像 1 General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 7、 2の画像 2
    • Pull the black cable straight off of its spade connector on the power switch diaphragm.
  8. General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 8、 3の画像 1 General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 8、 3の画像 2 General Pipe Cleaners Drain Cleaner EJB 2014 Reverse Switch Replacement: 手順 8、 3の画像 3
    • Slide the switch assembly down out of its hole in the control box and pull it out of the control box.
    • Be careful not to snag the switch on any cables during removal.
終わりに
2 の人々がこのガイドを完成させました。
Adam O'Camb
メンバー登録日: 04/11/15
217,114 ポイント
416のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 13
今までの合計 1,397
