メインコンテンツにスキップ
General Electric Telephone 2-9710A 3V Headset Battery Replacement
必要な工具と部品
  1. General Electric Telephone 2-9710A 3V Headset Battery Replacement, Phone Cord: 手順 1、 2の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement, Phone Cord: 手順 1、 2の画像 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 2、 3の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 2、 3の画像 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 2、 3の画像 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. General Electric Telephone 2-9710A 3V Headset Battery Replacement, General Electric Telephone 2-9710A Handset: 手順 3、 2の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement, General Electric Telephone 2-9710A Handset: 手順 3、 2の画像 2
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 4、 1の画像 1
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 5、 2の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 5、 2の画像 2
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 6、 2の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 6、 2の画像 2
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 7、 1の画像 1
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 8、 2の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 8、 2の画像 2
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 9、 2の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 9、 2の画像 2
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 10、 1の画像 1
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
  11. General Electric Telephone 2-9710A 3V Headset Battery Replacement, 3V Headset Battery: 手順 11、 1の画像 1
    • Use tweezers to apply pressure on battery holder tabs.
    • Apply pressure directly on battery holder to slide it through the shell.
    • Battery is going to slide through the bottom.
  12. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 12、 2の画像 1 General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 12、 2の画像 2
    • Lift tabs on the side of the holder by putting your fingers directly on the tab to pull it apart.
    • While holding the battery, remove it from the holder.
  13. General Electric Telephone 2-9710A 3V Headset Battery Replacement: 手順 13、 1の画像 1
    • Now insert the new battery.
    • Ensure that the positive side of the battery is facing the tabs.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Norberto Sanchez
メンバー登録日: 09/26/12
70 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G59
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,282
