はじめに
This guide will demonstrate how to remove the LCD screen and replace it with a new one.
必要な工具と部品
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
With the back casing that you just separated from the camera, use your finger to push the LCD screen from the frame.
終わりに
ある他の人がこのガイドを完成しました。
