メインコンテンツにスキップ
General Electric Bagel Switch 4-Slice Power Supply Replacement
必要な工具と部品
  1. General Electric Bagel Switch 4-Slice Power Supply Replacement, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: 手順 1、 1の画像 1
    • Unplug the toaster from the electrical outlet.
  2. General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 2、 2の画像 1 General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 2、 2の画像 2
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 3、 1の画像 1
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
  4. General Electric Bagel Switch 4-Slice Power Supply Replacement, Power Supply: 手順 4、 1の画像 1
    • Flip the toaster over so that the bottom plate is facing up.
  5. General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 5、 2の画像 1 General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 5、 2の画像 2
    • Remove the four screws from the bottom of the toaster.
    • Carefully separate the bottom plate from the metal components inside the toaster.
  6. General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 7、 1の画像 1
    • Using wire cutters, cut the power supply cable close to the base of the toaster, leave about 2 inches of wire.
  7. General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 8、 1の画像 1
    • Pull the power supply cord through the bottom plate of the toaster.
    • Insert the end of the new power supply cable through the hole in the bottom plate.
  8. General Electric Bagel Switch 4-Slice Power Supply Replacement: 手順 10、 1の画像 1
    • Strip about an inch of the wire insulation (casing) off the ends of both the new power supply cable, and the old power supply cable that is still attached to the toaster.
    • Splice the stripped ends of wire together using a wire cap.
終わりに
作成者
8人の作成者と共同で作成されました。
Ron Gajdos
メンバー登録日: 10/16/13
307 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013人のメンバー
UMASSD-VIJAYBHASKAR-F13S4G4
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 498
