はじめに
If you are having issues with battery life or charging, use this guide to replace the battery.
必要な工具と部品
Insert the plastic opening tool into the seam between the front of the device and the rear cover.
Slide the plastic opening tool from the bottom of the phone to the top.
Use the plastic opening tool to free all the clips attached to the phone.
ある他の人がこのガイドを完成しました。
4 件のコメント
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
