メインコンテンツにスキップ
GeeksPhone Keon Antenna Replacement
必要な工具と部品
  1. GeeksPhone Keon  Antenna Replacement, Battery: 手順 1、 2の画像 1 GeeksPhone Keon  Antenna Replacement, Battery: 手順 1、 2の画像 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon  Antenna Replacement: 手順 2、 1の画像 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon  Antenna Replacement: 手順 3、 1の画像 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon  Antenna Replacement, Back Plate: 手順 4、 2の画像 1 GeeksPhone Keon  Antenna Replacement, Back Plate: 手順 4、 2の画像 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon  Antenna Replacement: 手順 5、 2の画像 1 GeeksPhone Keon  Antenna Replacement: 手順 5、 2の画像 2
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon  Antenna Replacement: 手順 6、 1の画像 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon  Antenna Replacement: 手順 7、 3の画像 1 GeeksPhone Keon  Antenna Replacement: 手順 7、 3の画像 2 GeeksPhone Keon  Antenna Replacement: 手順 7、 3の画像 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon  Antenna Replacement: 手順 8、 2の画像 1 GeeksPhone Keon  Antenna Replacement: 手順 8、 2の画像 2
    • Lift the backplate away from the device.
  9. GeeksPhone Keon  Antenna Replacement, Antenna: 手順 9、 1の画像 1
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
  10. GeeksPhone Keon  Antenna Replacement: 手順 10、 3の画像 1 GeeksPhone Keon  Antenna Replacement: 手順 10、 3の画像 2 GeeksPhone Keon  Antenna Replacement: 手順 10、 3の画像 3
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
終わりに
作成者
3人の作成者と共同で作成されました。
Michael Moran
メンバー登録日: 08/26/15
113 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015人のメンバー
USFT-EYESTONE-F15S3G5
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 245
