はじめに
A running cistern can waste a lot of water - a repair is urgently needed. Actually, this can have two causes: either the seal at the outlet of the box is leaking (the bell seal), but more often the seal at the inlet valve is defective, this case is described here.
Note: this is an older, no longer up-to-date version of the Geberit toilet flush.
必要な工具と部品
Lift pressure plate from bottom to top, then remove
first unscrew the outer frame
then the inner cover. Carefully pull away to the front.
The filling valve. Photo 1 with the surface box.
Photo 2 shows the valve in the flush-mounted box.
With a water pump pliers, you loosen the union nut on the valve. So it is separated from the water inlet.
Remove the hose slowly so that no part falls out.
With the surface-mounted box you can simply push the valve upwards.
With the flush-mounted box, lift the valve upwards and set it aside. then push on the upper part until the float releases.
Now you can lift out the parts.
Repeat the steps in reverse order to reassemble your device.
4 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
3 件のコメント
I don’t like Geberit toilet. My all time favorite flushing toilet is American standard https://bestflushingtoilet.org/american-.... Really, I like this brand flushing technology.
That’s a great effort to share information about the Geberit toilet, but I think most people do not use these toilets. Here https://lueliving.com/ is a list of some best toilest. I’m sure that will be helpful.
In Europe, Geberit is very popular, and it is one of the few brands that provides parts/upgrades for older models (even going back to 1964, when they started).
