メインコンテンツにスキップ
Geardup RC Ford Mustang GT Remote Circuit Board Replacement
必要な工具と部品
  1. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 手順 1、 3の画像 1 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 手順 1、 3の画像 2 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 手順 1、 3の画像 3
    • Remove the 5mm Phillips #0 screw from the remote control.
    • Using the tab, lift the battery cover from the remote control to expose the battery.
  2. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: 手順 2、 2の画像 1 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: 手順 2、 2の画像 2
    • Unscrew the six 5mm Phillips #0 screws on the back of the remote
    • Separate the back of the remote from the front panel.
    • During re-assembly, make sure the plastic button covers on the front panel align with the buttons on the back panel. If they do not, the buttons may be forced into an always "pressed" state.
  3. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 手順 3、 1の画像 1
    • Remove the two left and right buttons from their insets in the controller.
  4. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 手順 4、 1の画像 1
    • Remove the 5mm Phillips #0 screw that connects the antennae to the circuit board.
  5. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 手順 5、 1の画像 1
    • Unscrew 5mm Phillips #0 screw located at the bottom of the board in the center.
    • Remove the circuit board from the casing.
  6. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 手順 6、 1の画像 1
    • Make note of where each wire connects to the circuit board for re-assembly as they will be removed in the next step.
    • Using the copper solder wick, remove the solder connecting the nine wires to the circuit board.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jake Stone
メンバー登録日: 02/01/15
611 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-38, Amido Winter 2015 Cal Poly, Team 8-38, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G38
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 6,061
