はじめに
In order to replace the motors or circuit board for the car, you need to open up the enclosure where they are housed. Use the following steps to open the motor/circuit board enclosure.
必要な工具と部品
Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
Gently lift the battery cover from the car to expose the batteries.
Flip the car over and remove the four 5mm Phillips #0 screws that hold the shell to the car chassis.
Unscrew and remove the 5mm Phillips #0 screw located at the center of the wheel while holding the wheel still.
Slide the wheel off of the axle.
Repeat the previous steps for the other rear wheel.
Remove the eight 5mm Phillips #0 screws located on the top of the motor/circuit board enclosure.
Vertically lift the motor/circuit board enclosure from the car chassis.
