メインコンテンツにスキップ
Geardup RC Ford Mustang GT Motor Replacement Guide
必要な工具と部品
  1. Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 手順 1、 3の画像 1 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 手順 1、 3の画像 2 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 手順 1、 3の画像 3
    • Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
    • Gently lift the battery cover from the car to expose the batteries.
  2. Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: 手順 2、 2の画像 1 Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: 手順 2、 2の画像 2
    • Flip the car over and remove the four 5mm Phillips #0 screws that hold the shell to the car chassis.
  3. Geardup RC Ford Mustang GT Motor Replacement Guide, Shell: 手順 3、 1の画像 1
    • Flip the car over again to its upright position and vertically lift the shell from the car.
    • During re-assembly, make sure the shell is correctly aligned. If it is not aligned correctly, it may rub on the wheels, possibly preventing them from turning.
  4. Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: 手順 4、 2の画像 1 Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: 手順 4、 2の画像 2
    • Unscrew and remove the 5mm Phillips #0 screw located at the center of the wheel while holding the wheel still.
    • Slide the wheel off of the axle.
    • Repeat the previous steps for the other rear wheel.
  5. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: 手順 5、 2の画像 1 Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: 手順 5、 2の画像 2
    • Remove the eight 5mm Phillips #0 screws located on the top of the motor/circuit board enclosure.
    • Vertically lift the motor/circuit board enclosure from the car chassis.
  6. Geardup RC Ford Mustang GT Motor Replacement Guide: 手順 6、 2の画像 1 Geardup RC Ford Mustang GT Motor Replacement Guide: 手順 6、 2の画像 2
    • Using a small plastic opening tool, gently pry the clips to release the tabs on the circuit board casing. The clips can be located above where the rear wheels used to be.
    • Lift the clips just enough to release them from the tabs. If they are pried too far, they may snap off.
    • There is a clear gear grease inside the enclosure.
  7. Geardup RC Ford Mustang GT Motor Replacement Guide: 手順 7、 2の画像 1 Geardup RC Ford Mustang GT Motor Replacement Guide: 手順 7、 2の画像 2
    • Lift the circuit board casing from the enclosure to reveal the motors, gears, and circuit board.
    • During re-assembly, make sure the wires are not pinched between plastic dividers in the enclosure as this may damage them.
  8. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor: 手順 8、 1の画像 1
    • Using the copper solder wick, remove the solder from the two wires at the points where they connect to the motor.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Matthew Seno
メンバー登録日: 02/01/15
191 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-38, Amido Winter 2015 Cal Poly, Team 8-38, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G38
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 395
