メインコンテンツにスキップ
Gateway W350I Display Replacement
必要な工具と部品
  1. Gateway W350I Display Replacement, Battery Access: 手順 1、 1の画像 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: 手順 2、 3の画像 1 Gateway W350I Display Replacement, Unlocking the Battery: 手順 2、 3の画像 2 Gateway W350I Display Replacement, Unlocking the Battery: 手順 2、 3の画像 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 手順 3、 2の画像 1 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 手順 3、 2の画像 2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
    These pictures look like they might be out of order. The second picture looks like the screw has been removed.
    Proofread the text in the first bullet point of this step.
    I don't see the rubber protectors that you mention.
    Dan Brown - 返信
  4. Gateway W350I Display Replacement, Separate Plastic Casing: 手順 4、 2の画像 1 Gateway W350I Display Replacement, Separate Plastic Casing: 手順 4、 2の画像 2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
    I'm not quite sure what I'm supposed to be seeing in the second picture. Where/what are the clip connectors that you mention?
    Dan Brown - 返信
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 手順 5、 2の画像 1 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 手順 5、 2の画像 2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: 手順 6、 1の画像 1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: 手順 7、 2の画像 1 Gateway W350I Display Replacement, Remove Video Cable: 手順 7、 2の画像 2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
    I could use clarification as to why steps 7 and 8 are here. The introduction suggests that this guide shows how to replace the screen, so why would I need to do these as well?
    Dan Brown - 返信
  8. Gateway W350I Display Replacement: 手順 8、 2の画像 1 Gateway W350I Display Replacement: 手順 8、 2の画像 2
    • Disconnect the camera connector from the circuit board to completely free the screen.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Samuel Newton
メンバー登録日: 09/22/14
296 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G1
3 メンバー
10のガイドは作成済み
コメント 1 件
It was very easy to follow.
Very friendly guide.
Stephan Williams - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,245
