メインコンテンツにスキップ
Gateway W350I Display Replacement
必要な工具と部品
  1. Gateway W350I Display Replacement, Battery Access: 手順 1、 1の画像 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: 手順 2、 3の画像 1 Gateway W350I Display Replacement, Unlocking the Battery: 手順 2、 3の画像 2 Gateway W350I Display Replacement, Unlocking the Battery: 手順 2、 3の画像 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 手順 3、 2の画像 1 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 手順 3、 2の画像 2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
  4. Gateway W350I Display Replacement, Separate Plastic Casing: 手順 4、 2の画像 1 Gateway W350I Display Replacement, Separate Plastic Casing: 手順 4、 2の画像 2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 手順 5、 2の画像 1 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 手順 5、 2の画像 2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: 手順 6、 1の画像 1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: 手順 7、 2の画像 1 Gateway W350I Display Replacement, Remove Video Cable: 手順 7、 2の画像 2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
  8. Gateway W350I Display Replacement: 手順 8、 2の画像 1 Gateway W350I Display Replacement: 手順 8、 2の画像 2
    • Disconnect the camera connector from the circuit board to completely free the screen.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Samuel Newton
メンバー登録日: 09/22/14
296 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G1
3 メンバー
10のガイドは作成済み
コメント 1 件
It was very easy to follow.
Very friendly guide.
Stephan Williams - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 1,261
