メインコンテンツにスキップ
Gateway Solo 1200 Keyboard and Frame Replacement
必要な工具と部品
  1. Gateway Solo 1200 Keyboard and Frame Replacement, Battery: 手順 1、 3の画像 1 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: 手順 1、 3の画像 2 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: 手順 1、 3の画像 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: 手順 2、 2の画像 1 Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: 手順 2、 2の画像 2
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Keyboard and Frame Replacement: 手順 3、 2の画像 1 Gateway Solo 1200 Keyboard and Frame Replacement: 手順 3、 2の画像 2
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Keyboard and Frame Replacement: 手順 4、 3の画像 1 Gateway Solo 1200 Keyboard and Frame Replacement: 手順 4、 3の画像 2 Gateway Solo 1200 Keyboard and Frame Replacement: 手順 4、 3の画像 3
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Keyboard and Frame Replacement: 手順 5、 3の画像 1 Gateway Solo 1200 Keyboard and Frame Replacement: 手順 5、 3の画像 2 Gateway Solo 1200 Keyboard and Frame Replacement: 手順 5、 3の画像 3
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Keyboard and Frame Replacement: 手順 6、 3の画像 1 Gateway Solo 1200 Keyboard and Frame Replacement: 手順 6、 3の画像 2 Gateway Solo 1200 Keyboard and Frame Replacement: 手順 6、 3の画像 3
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
終わりに
作成者
5人の作成者と共同で作成されました。
Riki
メンバー登録日: 08/26/19
235 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S1-G3, Friess Fall 2019 University of North Texas, Team S1-G3, Friess Fall 2019人のメンバー
UNT-FRIESS-F19S1G3
3 メンバー
38のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 247
