メインコンテンツにスキップ
Gateway Solo 1200 Diskette Drive Replacement
必要な工具と部品
  1. Gateway Solo 1200 Diskette Drive Replacement, Battery: 手順 1、 3の画像 1 Gateway Solo 1200 Diskette Drive Replacement, Battery: 手順 1、 3の画像 2 Gateway Solo 1200 Diskette Drive Replacement, Battery: 手順 1、 3の画像 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Diskette Drive Replacement, Keyboard and Frame: 手順 2、 2の画像 1 Gateway Solo 1200 Diskette Drive Replacement, Keyboard and Frame: 手順 2、 2の画像 2
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Diskette Drive Replacement: 手順 3、 2の画像 1 Gateway Solo 1200 Diskette Drive Replacement: 手順 3、 2の画像 2
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Diskette Drive Replacement: 手順 4、 3の画像 1 Gateway Solo 1200 Diskette Drive Replacement: 手順 4、 3の画像 2 Gateway Solo 1200 Diskette Drive Replacement: 手順 4、 3の画像 3
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Diskette Drive Replacement: 手順 5、 3の画像 1 Gateway Solo 1200 Diskette Drive Replacement: 手順 5、 3の画像 2 Gateway Solo 1200 Diskette Drive Replacement: 手順 5、 3の画像 3
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Diskette Drive Replacement: 手順 6、 3の画像 1 Gateway Solo 1200 Diskette Drive Replacement: 手順 6、 3の画像 2 Gateway Solo 1200 Diskette Drive Replacement: 手順 6、 3の画像 3
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
  7. Gateway Solo 1200 Diskette Drive Replacement, Diskette Drive: 手順 7、 1の画像 1
    • Rotate the device so the battery compartment is located at the bottom.
    • Locate the diskette drive directly above the battery compartment on the left side.
  8. Gateway Solo 1200 Diskette Drive Replacement: 手順 8、 3の画像 1 Gateway Solo 1200 Diskette Drive Replacement: 手順 8、 3の画像 2 Gateway Solo 1200 Diskette Drive Replacement: 手順 8、 3の画像 3
    • Turn the device so the battery compartment is now located on the right side.
    • Locate and unscrew the two screws securing the diskette drive.
    • The first screw is to the left of the diskette drive, near the edge of the laptop. The second is above the diskette drive, near the center of the diskette drive.
  9. Gateway Solo 1200 Diskette Drive Replacement: 手順 9、 2の画像 1 Gateway Solo 1200 Diskette Drive Replacement: 手順 9、 2の画像 2
    • Locate the ribbon cable at the top of the diskette drive.
    • Gently pull ribbon cable to detach diskette drive from the motherboard.
  10. Gateway Solo 1200 Diskette Drive Replacement: 手順 10、 1の画像 1
    • Once screws have been removed and ribbon cable detached, gently slide the diskette drive out of the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Diana Farris
メンバー登録日: 08/27/19
290 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G3, Friess Fall 2019 University of North Texas, Team S1-G3, Friess Fall 2019人のメンバー
UNT-FRIESS-F19S1G3
3 メンバー
38のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 371
