メインコンテンツにスキップ
Gateway SA1 Screen Replacement
必要な工具と部品
  1. Gateway SA1 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Screen Replacement: 手順 2、 1の画像 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Screen Replacement, Screen: 手順 3、 2の画像 1 Gateway SA1 Screen Replacement, Screen: 手順 3、 2の画像 2
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
  4. Gateway SA1 Screen Replacement: 手順 4、 2の画像 1 Gateway SA1 Screen Replacement: 手順 4、 2の画像 2
    • Remove the six screw covers on the front bezel with the sharp point of the spudger.
    • The bottom two are more difficult to remove.
  5. Gateway SA1 Screen Replacement: 手順 5、 1の画像 1
    • Remove the six 5.9 mm Philips screws securing the screen bezel.
  6. Gateway SA1 Screen Replacement: 手順 6、 3の画像 1 Gateway SA1 Screen Replacement: 手順 6、 3の画像 2 Gateway SA1 Screen Replacement: 手順 6、 3の画像 3
    • Remove the front bezel by prying it off with the wedged end of the spudger.
    • Verify that your spudger does not touch the LCD.
    • The screen inverter is now exposed below the LCD.
  7. Gateway SA1 Screen Replacement: 手順 7、 1の画像 1
    • Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
  8. Gateway SA1 Screen Replacement: 手順 8、 2の画像 1 Gateway SA1 Screen Replacement: 手順 8、 2の画像 2
    • Use your finger, or the spudger, to pry the inverter board out.
    • This exposes the wires behind it.
  9. Gateway SA1 Screen Replacement: 手順 9、 1の画像 1
    • Unplug the LCD back light cables from the right side of the screen inverter.
  10. Gateway SA1 Screen Replacement: 手順 10、 2の画像 1 Gateway SA1 Screen Replacement: 手順 10、 2の画像 2
    • Remove the six screws that mount the screen to the hinge mounts.
    • Two 2.5 mm Phillips screws.
    • Four 3.8 mm Phillips screws.
  11. Gateway SA1 Screen Replacement: 手順 11、 1の画像 1
    • Unplug the cable from the webcam board.
    • Be gentle, do not use excessive force or you may break the connection.
  12. Gateway SA1 Screen Replacement: 手順 12、 1の画像 1
    • Separate the screen from the display cover.
    • Do not touch the back of the screen.
  13. Gateway SA1 Screen Replacement: 手順 13、 2の画像 1 Gateway SA1 Screen Replacement: 手順 13、 2の画像 2
    • Remove the three tape strips that hold down the cables.
    • Be careful not to tear any of the tape. The piece holding down the webcam wires is especially delicate.
  14. Gateway SA1 Screen Replacement: 手順 14、 2の画像 1 Gateway SA1 Screen Replacement: 手順 14、 2の画像 2
    • Unplug the display data cable from the screen connector.
    • This connection is very fragile; do not use excessive force.
    • The screen should now be free from all wire connections.
  15. Gateway SA1 Screen Replacement: 手順 15、 1の画像 1
    • Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
    • There will be two screws on either side of the mounting bracket.
  16. Gateway SA1 Screen Replacement: 手順 16、 1の画像 1
    • You can now remove and replace the screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Diego Carteno
メンバー登録日: 04/15/10
273 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S24G20
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 19,102
