メインコンテンツにスキップ
Gateway NV55C49u USB Port Replacement
必要な工具と部品
  1. Gateway NV55C49u USB Port Replacement, USB Port: 手順 1、 1の画像 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u USB Port Replacement: 手順 2、 1の画像 1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u USB Port Replacement: 手順 3、 2の画像 1 Gateway NV55C49u USB Port Replacement: 手順 3、 2の画像 2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u USB Port Replacement: 手順 4、 2の画像 1 Gateway NV55C49u USB Port Replacement: 手順 4、 2の画像 2
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  5. Gateway NV55C49u USB Port Replacement: 手順 5、 1の画像 1
    • Remove all nine 6.0mm #00 Phillips screws from the back of the laptop.
  6. Gateway NV55C49u USB Port Replacement: 手順 6、 1の画像 1
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u USB Port Replacement: 手順 7、 1の画像 1
    • Flip the laptop over so that the cover faces you.
    • Open the laptop so you can see the keyboard.
  8. Gateway NV55C49u USB Port Replacement: 手順 8、 1の画像 1
    • Push in the tabs that are located around the keyboard using the triangle scalpel tool.
    • This should release the keyboard so it can be pulled up
  9. Gateway NV55C49u USB Port Replacement: 手順 9、 1の画像 1
    • Slowly lift up the keyboard away from the laptop.
    • Push on the sides on the black ribbon cable using 2 plastic opening tools to release it.
  10. Gateway NV55C49u USB Port Replacement: 手順 10、 1の画像 1
    • Remove the 3 ribbon cables that are showing using the plastic opening tools.
  11. Gateway NV55C49u USB Port Replacement: 手順 11、 2の画像 1 Gateway NV55C49u USB Port Replacement: 手順 11、 2の画像 2
    • Remove the disk drive cover on the right side of the laptop using the plastic opening tool.
    • Slide the disc drive out of its compartment, using the metal spudger.
  12. Gateway NV55C49u USB Port Replacement: 手順 12、 1の画像 1
    • Lift the face plate off the laptop body.
  13. Gateway NV55C49u USB Port Replacement: 手順 13、 1の画像 1
    • Remove the 6.0 mm Phillips #00 screw that holds in the USB port.
  14. Gateway NV55C49u USB Port Replacement: 手順 14、 1の画像 1
    • Push on the sides of the white ribbon cable that is attached to the motherboard using the 2 plastic opening tools to release it.
終わりに
作成者
3人の作成者と共同で作成されました。
Micaela
メンバー登録日: 10/16/18
329 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S8-G1, Riccardelli Fall 2018 University of North Texas, Team S8-G1, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S8G1
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 19
今までの合計 711
