メインコンテンツにスキップ
Gateway NV55C49u Display Replacement
必要な工具と部品
  1. Gateway NV55C49u Display Replacement, Display: 手順 1、 1の画像 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Display Replacement: 手順 2、 1の画像 1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u Display Replacement: 手順 3、 2の画像 1 Gateway NV55C49u Display Replacement: 手順 3、 2の画像 2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u Display Replacement: 手順 4、 1の画像 1
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u Display Replacement: 手順 5、 2の画像 1 Gateway NV55C49u Display Replacement: 手順 5、 2の画像 2
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  6. Gateway NV55C49u Display Replacement: 手順 6、 1の画像 1
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u Display Replacement: 手順 7、 1の画像 1
    • Remove the two 6.0mm #00 Phillips screws from the area under the back cover.
  8. Gateway NV55C49u Display Replacement: 手順 8、 1の画像 1
    • Remove the nine 6.0mm #00 Phillips screws from the back of the laptop.
  9. Gateway NV55C49u Display Replacement: 手順 9、 3の画像 1 Gateway NV55C49u Display Replacement: 手順 9、 3の画像 2 Gateway NV55C49u Display Replacement: 手順 9、 3の画像 3
    • There are 6 small clips that holding the top row of the keyboard in place.
    • To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
    • Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
  10. Gateway NV55C49u Display Replacement: 手順 10、 1の画像 1
    • Once the keyboard is loose, slowly lift the keyboard away from the laptop.
    • There will be a single ribbon cable connecting the keyboard to the laptop body. Use two plastic opening tools to loosen the fastener,
    • After the fastener is loose, gently disconnect the cable.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much pressure.
  11. Gateway NV55C49u Display Replacement: 手順 11、 3の画像 1 Gateway NV55C49u Display Replacement: 手順 11、 3の画像 2 Gateway NV55C49u Display Replacement: 手順 11、 3の画像 3
    • Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much force.
    • Use a plastic pry tool to disconnect the single pinned connector.
  12. Gateway NV55C49u Display Replacement: 手順 12、 1の画像 1
    • Use a plastic opening tool to remove the disk drive cover on the right side of the laptop.
  13. Gateway NV55C49u Display Replacement: 手順 13、 2の画像 1 Gateway NV55C49u Display Replacement: 手順 13、 2の画像 2
    • Use the metal spudger to pry upwards on the disk drive until you can grab and remove it.
  14. Gateway NV55C49u Display Replacement: 手順 14、 1の画像 1
    • Now simply lift the face-plate off the laptop body.
    • This step exposes the motherboard, which is a sensitive part of the laptop. Make sure not to touch anything with your bare hands as a static shock could ruin the board.
  15. Gateway NV55C49u Display Replacement: 手順 15、 1の画像 1
    • Remove the ribbon wire that connects the display to the motherboard using two plastic opening tools.
  16. Gateway NV55C49u Display Replacement: 手順 16、 2の画像 1 Gateway NV55C49u Display Replacement: 手順 16、 2の画像 2
    • Remove the two 4.0mm #00 Phillips screws from both the top right and top left of the exposed laptop body.
    • The display is now fully disconnected.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Matthew
メンバー登録日: 09/23/18
385 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S8-G1, Riccardelli Fall 2018 University of North Texas, Team S8-G1, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S8G1
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 340
