この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
As your laptop ages, drops, spills, and time can cause damage to your laptop screen. If the image is often distorted, the LD light is corrupt, or just a blatant crack in the screen, you can follow these steps to easily replace your screen. Replacing the screen will allow for a better image as well as an easier use of your device, without the frustration of looking at an unsatisfactory display.
必要な工具と部品
Using the spudger, remove the protective caps for the screen to expose the screws.
Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
ある他の人がこのガイドを完成しました。
