はじめに
Removing the upper case of the laptop is necessary if the case is significantly damaged since it is essentially to protecting the laptop's internal components. Upper case removal is also a necessary preliminary step for replacing many of these internal components. Remove battery before upper cover case.
必要な工具と部品
After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
もう少しです!
終わりに
