この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is your computer experiencing significant problems with loading or booting up in general? Consider using this guide to replace the motherboard of your device. This guide will walk you through removing the motherboard, but when you remove the motherboard the fan will also be attached.
必要な工具と部品
After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
もう少しです!
終わりに
