メインコンテンツにスキップ
はじめに
Is your computer making loud noises and taking longer than normal to boot? Consider using this guide to replace the cooling fan in your device.
  1. Make sure to power down and turn off the laptop before proceeding with this guide.
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Slide the tab to the left and hold the tab there. While holding down the sliding tab, remove the battery from the device.
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. After removing the battery,  remove 15  7mm screws using the Phillip #1 Screwdriver. After removing the battery,  remove 15  7mm screws using the Phillip #1 Screwdriver.
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Flip over the laptop and open it so the screen is facing you.
    • Flip over the laptop and open it so the screen is facing you.
  5. Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Remove the twelve 3mm screws using the Phillips #00 screwdriver.
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gently lift and remove the motherboard off of device. This will also remove the fan from the device but it will remain attached to the motherboard.
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
  8. Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
    • Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
  9. Gently lift the fan and disconnect the fan from the motherboard. Remove the fan from the device.
    • Gently lift the fan and disconnect the fan from the motherboard.
    • Remove the fan from the device.
終わりに
Kelsey Rodrigues
メンバー登録日: 2018年10月23日
495 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G1, Simcock Fall 2018 UMass Dartmouth, Team S1-G1, Simcock Fall 2018人のメンバー
UMASSD-SIMCOCK-F18S1G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 24
今までの合計 81
