メインコンテンツにスキップ
Gateway NE52203u Optical Drive Replacement
必要な工具と部品
  1. Gateway NE52203u Optical Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip the device over onto its backside in order to access the battery.
  2. Gateway NE52203u Optical Drive Replacement: 手順 2、 2の画像 1 Gateway NE52203u Optical Drive Replacement: 手順 2、 2の画像 2
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
  3. Gateway NE52203u Optical Drive Replacement: 手順 3、 1の画像 1
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
  4. Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: 手順 4、 2の画像 1 Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: 手順 4、 2の画像 2
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  5. Gateway NE52203u Optical Drive Replacement: 手順 5、 1の画像 1
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  6. Gateway NE52203u Optical Drive Replacement: 手順 6、 2の画像 1 Gateway NE52203u Optical Drive Replacement: 手順 6、 2の画像 2
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  7. Gateway NE52203u Optical Drive Replacement: 手順 7、 1の画像 1
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  8. Gateway NE52203u Optical Drive Replacement: 手順 8、 3の画像 1 Gateway NE52203u Optical Drive Replacement: 手順 8、 3の画像 2 Gateway NE52203u Optical Drive Replacement: 手順 8、 3の画像 3
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
  9. Gateway NE52203u Optical Drive Replacement, Optical Drive: 手順 9、 3の画像 1 Gateway NE52203u Optical Drive Replacement, Optical Drive: 手順 9、 3の画像 2 Gateway NE52203u Optical Drive Replacement, Optical Drive: 手順 9、 3の画像 3
    • Grasp the plastic placeholder firmly and slide it out of the computer.
    • When inserting replacement optical drive, use the port at the back left of the open space.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Stephen Spees
メンバー登録日: 03/20/15
542 ポイント
4のガイドは作成済み
チーム
Baylor, Team 2-1, Grigsby Spring 2015 Baylor, Team 2-1, Grigsby Spring 2015人のメンバー
BU-GRIGSBY-S15S2G1
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 422
