Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
This cable has a special connector the requires you to lift open a grey flap to unplug properly.
The keyboard plug is located at the center of the motherboard and can be unplugged like a normal cable.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
