Slide the long slider towards the unlocked lock icon.
This slider is spring loaded and may require a little force.
If done correctly, a click will be heard and the battery will be slightly raised.
Push the upper RAM module's two pins outwards at the same time.
If done correctly, the module should have lifted.
Push the lower RAM module's two pins outwards at the same time.
Like removing the upper module, grab the module and pull away in a straight direction.
Do not touch the gold connectors.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
