メインコンテンツにスキップ
Gateway MD2614u Processor Replacement
必要な工具と部品
  1. Gateway MD2614u Processor Replacement, Back Cover: 手順 1、 1の画像 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: 手順 2、 1の画像 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: 手順 3、 1の画像 1
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: 手順 4、 1の画像 1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: 手順 5、 1の画像 1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: 手順 6、 1の画像 1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: 手順 7、 1の画像 1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: 手順 8、 1の画像 1
    この手順で使用する道具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    購入する
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: 手順 9、 1の画像 1
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
終わりに
2 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Toni Pipes
メンバー登録日: 10/05/10
333 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S21G31
4 メンバー
14のガイドは作成済み
コメント 1 件
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 7,147
