はじめに
The Central Processing Unit (CPU) is an integral part of your computer's speed and ability to process information. A damaged CPU may cause your computer to become slow and unstable, resulting in frequent crashes or even inability to boot. Replacing the CPU will enhance the speed and overall performance of your device. Because of its importance, it can get very expensive to replace. This simple and easy-to-follow guide that requires no special skills will walk you through the steps of replacing the CPU for a Gateway MD2614u.
必要な工具と部品
この手順で使用する道具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
The CPU is located under the heat sink you just removed.
Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
2 の人々がこのガイドを完成させました。
コメント 1 件
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - 返信
