はじめに
If your laptop keeps crashing or is running slow, then consider replacing the RAM of your device using this guide here.
必要な工具と部品
Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
もう少しです!
終わりに
