メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Gateway LT41P10u Cooling Fan Replacement
必要な工具と部品
  1. Gateway LT41P10u Cooling Fan Replacement, Battery: 手順 1、 1の画像 1
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Gateway LT41P10u Cooling Fan Replacement: 手順 2、 1の画像 1
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  3. Gateway LT41P10u Cooling Fan Replacement: 手順 3、 1の画像 1
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
  4. Gateway LT41P10u Cooling Fan Replacement, Keyboard: 手順 4、 2の画像 1 Gateway LT41P10u Cooling Fan Replacement, Keyboard: 手順 4、 2の画像 2
    • Once the battery is removed, flip the laptop over and open it up so you can see the keyboard.
    • Underneath the f4, f8, and f12 keys there are indents (see the second image) to fit a spudger or plastic opening tool to pop the keyboard off.
    • Once you find an indent with your spudger, carefully move it so the top of the keyboard comes away from the rest of the computer, followed by the bottom of the keyboard.
  5. Gateway LT41P10u Cooling Fan Replacement: 手順 5、 1の画像 1
    • Once you pull the keyboard off, you will see a ribbon wire connecting the keyboard to the rest of the laptop.
    • To detach the keyboard from the rest of the computer, you have to unlock the ribbon by pulling up on the small black lock keeping the ribbon from being removed. You won't have to pull very hard, so be gentle to avoid damaging it.
    • Once the ribbon is disconnected from the computer, you are able to pull the ribbon out from underneath the lock, and then pull the keyboard away.
  6. Gateway LT41P10u Cooling Fan Replacement, Track Pad: 手順 6、 3の画像 1 Gateway LT41P10u Cooling Fan Replacement, Track Pad: 手順 6、 3の画像 2 Gateway LT41P10u Cooling Fan Replacement, Track Pad: 手順 6、 3の画像 3
    • Remove screws from back plate using phillips screwdriver.
    • After removing the back screws use same phillips screwdriver to remove all screws from top plate. (see images 2 and 3, bottom screws from image 2 overlap with top screws from image 3.)
    • Once all screws are removed from top and bottom plates disconnect cable ribbon indicated by a red arrow in images 2 and 3.
  7. Gateway LT41P10u Cooling Fan Replacement: 手順 7、 2の画像 1 Gateway LT41P10u Cooling Fan Replacement: 手順 7、 2の画像 2
    • Carefully remove plate.
    • Track pad is located on the under side of the plate indicated by image 2.
    • To replace track pad you must replace the entire plate. (Track pad is permanently attached this plate.)
  8. Gateway LT41P10u Cooling Fan Replacement, Cooling Fan: 手順 8、 2の画像 1 Gateway LT41P10u Cooling Fan Replacement, Cooling Fan: 手順 8、 2の画像 2
    • By hand, remove the top left tape in order to free the tab underneath.
    • Remove the two small tabs at the bottom middle of the laptop and the whole board will be free.
    • The board may now be removed from the laptop
  9. Gateway LT41P10u Cooling Fan Replacement: 手順 9、 2の画像 1 Gateway LT41P10u Cooling Fan Replacement: 手順 9、 2の画像 2
    • Remove the wiring connector by hand or with the help of a flathead screwdriver if necessary.
    • Remove both screws with a philips head screwdriver.
    • The cooling fan is now completely removed and may be replaced with new parts.
終わりに
作成者
1人の作成者と共同作成されました。
Patrick Raposo
メンバー登録日: 10/21/17
201 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 UMass Dartmouth, Team S66-G8, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S66G8
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 38
今までの合計 517
