メインコンテンツにスキップ
Gateway LT4004u Screen Replacement
必要な工具と部品
  1. Gateway LT4004u Screen Replacement, Screen: 手順 1、 3の画像 1 Gateway LT4004u Screen Replacement, Screen: 手順 1、 3の画像 2 Gateway LT4004u Screen Replacement, Screen: 手順 1、 3の画像 3
    • Open the laptop so that the screen and keyboard are facing you.
    • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
  2. Gateway LT4004u Screen Replacement: 手順 2、 3の画像 1 Gateway LT4004u Screen Replacement: 手順 2、 3の画像 2 Gateway LT4004u Screen Replacement: 手順 2、 3の画像 3
    • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
  3. Gateway LT4004u Screen Replacement: 手順 3、 3の画像 1 Gateway LT4004u Screen Replacement: 手順 3、 3の画像 2 Gateway LT4004u Screen Replacement: 手順 3、 3の画像 3
    • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
    • Be prepared to hear cracking noises. These are expected.
    • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
    • Remove the screen casing.
  4. Gateway LT4004u Screen Replacement: 手順 4、 3の画像 1 Gateway LT4004u Screen Replacement: 手順 4、 3の画像 2 Gateway LT4004u Screen Replacement: 手順 4、 3の画像 3
    • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
    • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
  5. Gateway LT4004u Screen Replacement: 手順 5、 3の画像 1 Gateway LT4004u Screen Replacement: 手順 5、 3の画像 2 Gateway LT4004u Screen Replacement: 手順 5、 3の画像 3
    • Unplug the webcam connection from the top of the laptop screen backing.
  6. Gateway LT4004u Screen Replacement: 手順 6、 3の画像 1 Gateway LT4004u Screen Replacement: 手順 6、 3の画像 2 Gateway LT4004u Screen Replacement: 手順 6、 3の画像 3
    • Flip the screen over so that it is lying on top of the keyboard.
    • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
  7. Gateway LT4004u Screen Replacement: 手順 7、 1の画像 1
    • Remove the screen from the rest of the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Carlisle Hiott
メンバー登録日: 03/21/16
812 ポイント
7のガイドは作成済み
チーム
Clemson, Team 6-5, Benson Spring 2016 Clemson, Team 6-5, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S6G5
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 480
