はじめに
This guide will show the steps required to remove a broken speaker from the netbook, and replace it with a new speaker.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
コメントを追加する
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
コメントを追加する
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
コメントを追加する
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
コメントを追加する
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
コメントを追加する
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
コメントを追加する
  • Remove the 5mm screw of the left speaker cover using a Phillips #0 screwdriver, as shown here.
コメントを追加する
  • Disconnect the speaker's connection to the motherboard by lightly pulling on the connector until it pops apart from the motherboard.
コメントを追加する
  • Repeat the previous steps for the right speaker. Remove the 5mm screw of the right speaker cover using a Phillips #0 screwdriver.
コメントを追加する
コメントを追加する
コメントを追加する
まとめ
Emily
メンバー登録日: 2014年03月11日
301 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S3G2
4 メンバー
18のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 82
