Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
コメントを追加する
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
コメントを追加する
The RAM is located under this cover.
  • The RAM is located under this cover.
コメントを追加する
Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
  • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
  • Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
コメントを追加する
Unlock the RAM by pinching the metal clamps that keep the RAM in place. Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
  • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
  • Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
コメントを追加する
まとめ
Emily
メンバー登録日: 2014年03月11日
301 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S3G2
4 メンバー
18のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 105
