はじめに
Replacing the LCD will take some time, strength, and a sturdy plastic opening tool.
必要な工具と部品
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Carefully disconnect two ribbon cables to complete the separation of the upper cover.
