はじめに
Keys are easy to replace on a Gateway netbook. You can purchase keys online at Amazon, eBay, or the product page. Keys contain three parts: key cap, key retainer clip, and rubber cup. For this guide, we will replace the key cap.
Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
  • Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
コメントを追加する
Insert a plastic opening tool under the key to be removed. Insert a plastic opening tool under the key to be removed.
  • Insert a plastic opening tool under the key to be removed.
コメントを追加する
Put the opening tool underneath the key. Use force until the key pops up.
  • Put the opening tool underneath the key. Use force until the key pops up.
コメントを追加する
  • To replace the key, follow these instructions, but do them in reverse order (i.e., use the plastic opening tool to put the key back in place).
コメントを追加する
まとめ
My Linh Pham
メンバー登録日: 2014年03月11日
301 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S3G2
4 メンバー
18のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 230
